Sold Memphis MClass 4 Channel Amp
Mzlady
I'm selling a Memphis 16-MCA3004 4 channel amp, it is in good working condition with no problems. No I do not have the end caps for the amp. I'm doing a system change and this amp isnt in the plans so I'd like it gone. NO TRADES!! Asking $200 shipped OBO. NO LOW BALLERS. Paypal only! Here are specs and pics
Full MOSFET Design
Built-In Fully Variable High/Low Pass Crossovers
User Selectable 12dB or 18dB Per Octave Crossover Slope
RCA Bypass Output
Platinum Finish Wire Connections
Accepts 4 Gauge Power and Ground Wire
4-Channel MClass Series Amplifier
Compact Aluminum Chassis with Custon Black Pearl Finish
Gold Plated RCA Connectors
Full MOSFET Design
Fully Variable Crossover: HP/LP (40 Hz - 6 kHz)
4-Way Protection Circuitry
Optional Wired Remote Gain Control
Adjustable Input Sensitivity: 250mV - 5V
Dimensions: 18.5" L x 7.6" W x 2.4" H
Number of Channels 4
RMS Power (4 ohms) 75 watts x 4 chan.
RMS Power (2 ohms) 115 watts x 4 chan.
RMS Power (1 ohm) Not Stable
Bridged RMS Power 230 watts x 2 chan.
Peak Power Output 920 watts approx.
Min. Impedance Unbridged 2 ohms
Min. Impedance Bridged 4 ohms
THD @ Rated RMS Power 0.03%
Built-in Crossover HP (40 Hz - 6 kHz), LP (40 Hz - 6 kHz)
Signal-to-Noise Ratio 92 dB
Fuse Rating 25A x 2
Mzlady
Mzlady
OHIO
Mzlady
