memphis belle
  • 5
Nitefury360
Lacey wa
Item(s) for Sale: memphis belle 16-mch1300
Item(s) Description/Condition: 8.5-10 minor scratches
memphis belle 16-mch1300 wont fit in my new ride will trade for a smaller foot print amp of equal quality and cash it wont let me up load pics on photo bucket or as an atachment here are the links
Facebook
Facebook
Facebook
Facebook
Price: 400
Shipping and Miscellaneous Item Information: 20$
I was thinking about that. I have heard it is a quality amp. Then I wondered why don't these quality amps push more power? My tweeters and mids are rated at 100 wrms and my last amp probably pushed 50 wrms per channel. Was still loud. So now it's between a used/repaired Memphis Bells or a BNIB American Bass.
comes down to taste an pref how efficent is the ab?
Doesn't say.
American Bass PH-4100 FR Mini Phantom Series Series 4-Channel Car Amplifier
RMS Power Rating (14.4):
4 ohms: 120 watts x 4 chan.
2 ohms: 240 watts x 4 chan.
Mono Channel 1 ohm: 800 watts x 1
MOSFET power supply with high grade switching devices
LED power/protect indicators
Designed to fit into restrictive or limited spaces while still delivering staggering amounts of power
Ultra efficient Nano Technology power supplies and endless possible installation scenarios
Extreme power in a small footprint
Ultimate mounting flexibility (stackable, line array, side mount)
Mill Spec double sided PCB with SMD parts
Built-In noise reduction circuitry
Heavy duty aluminum alloy heatsink anodized in a Raven Black finish for extreme heat dissipation
3-Way protection circuitry (short circuit, overheating and Low Voltage)
Chrome-plated RCA level inputs
Chrome-plated screw terminals
Adjustable high-pass filter (40-200 Hz, 24 dB/octave)
Adjustable low-pass filter (20-200 Hz, 24 dB/octave)
Frequency response: 20-25,000 Hz
THD (Total Harmonic Distortion):
Signal-to-Noise Ratio: >89 dB
Max Voltage: 15V
Max RCA Voltage: 5V
4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
CEA-2006 compliant amplifier
Weight: 15 lbs
Dimensions: 15"L x 5-1/2"W x 2-1/8"H
1 Year Warranty
Doesn't say.
Max Voltage: 15V
Max RCA Voltage: 5V
Weight: 15 lbs
1 Year Warranty
amp you posted is a 4 ch not a 5 ch the memphis has a better thd rating n slightly better specs im confused as to y your comparing a 4 ch to a 5 ch ...
Don't be confused, LOL. I used the wrong spec sheet. The 5 channel has the same 4 channel power ratings. But I bet that is at max power per channel.
can you post a few better pics? I want to see these scratches you are talking about. This amp will be mounted to be visible in the hatch.
scratches are very very faint hard to even capture im just very picky about condition
  • Locked
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
https://caraudiobargain.com/audio-apex-cab-22-car-amplifier-monoblock-2200-watts-rms/ Since these are back in stock they're really hard to beat...
And the most important thing you've learned in life up to this point is to get offended on behalf of other people on the internet in the attempt...
18
5K
So recently I bought a Memphis prx1000.1 and installed it to 2 rockfordfosgate r1s'. Both svc and 150rms 4ohm. I wired them to a 2ohm load to the...
Nitefury360
Nitefury360
Lacey wa
m3dia_lab
