Sold Memphis AR-CH100??
jmward27
Beer Processor
All,
I had a friend that owed me some money who offered to give me this amp instead. Allegedly its one of the first models of Memphis amps and is 800 watts and .5 ohm rated. Anyone heard of it, heard it or know what its worth?
Reason I'm asking is it will be going on here if its worth something...got a little submit happy on the first post, sorry.
Found it... Actually is AR-HC100. Anyone interested?
Specs:
RMS Power 4 ohm: 50 x 2
RMS Power 2 ohm: 100 x 2
RMS Power 1 ohm: 200 x 2
RMS Power .5 ohm: 400 x 2
THD 4 ohm: .09%
S/N Ratio 95dB
Variable LP Filter: 50Hz – 250 Hz
Variable HP Filter 50Hz – 250 Hz
Filter Slopes 12 dB
Input Sensitivity 160mV-3.3V
Input Impedance 10kOhm
Freq Resp +/- 1db 20Hz-20kHz
Fuse Ration 100Ax1
Dimensions 9” x 2.2” x 17.1”
I just traded a buddy some audio stuff for this amp, originally it was powering one w7 in a jimmy and he kept blowing the w7's. Ive got to go get it outta pawn. Is this one hell of an amp? Im glad i see its .5 ohm steady, thats what im running at currently with my old excelon 301 though alot of cutting out, need a stronger amp and some time to run the big 3. Whats everyones opinion on the amp?
it is an indestructible amp in my opinion ....... its like a st1000d but one step higher only down fall is its large size.....I had a ar 500hc its worth atleast 250 300 if its in good condition all I run is memphis amps.......
it gets a little warm but doesn't shut down I ran my 50hc hard and had noooooooo problems and the only way my buddy fried his 100 hc was he spilled a gallon of milk on it while on his way home from the store it played for several minutes after that.......its a great amp good luck with it push it hard no worries 1 ohm mono only ,5 ohms for burps
jmward27
Beer Processor
jmward27
Iowa
suisidle
