Memphis amp question
alexkerhead
With Class, M-Class
OK, so, I got a 500watt rms class -D Memphis amplifier.
I am getting two 10 inch m-class, dual voice coils each.
I need to know, is there going to be too much strain on the amp with two dual voice coil subs?
I know I should have gone with svc, but too late.
Another question.
I dnt want to wire two terminal sets up for each speaker on the box I built, so is it ok if I wire the two voice coils together in a sequence, like pos, neg, pos, neg ?
Or do I need to just run them together acting as one voice coil?
I appreciate the help.
I always wanted a high quality memphis system, I finally am getting the chance to own one, so I dont want to fry anything.
Not a rule for the amps stability, however you might want to search the link for the ohms law rules,
shows you yor different options of wiring your subs to your amp. and how it affects the ohms
I think Rockford has such a link
Is the amplifier secure/bolted down or has it been moving around/just laid down in the vehicle not secure? I would check your wiring connections...
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
873
https://caraudiobargain.com/audio-apex-cab-22-car-amplifier-monoblock-2200-watts-rms/ Since these are back in stock they're really hard to beat...
914
And the most important thing you've learned in life up to this point is to get offended on behalf of other people on the internet in the attempt...
18
4K
alexkerhead
With Class, M-Class
alexkerhead
Montgomery, Al
alexkerhead
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
