Memphis 16-ST1000D
flaboy22
Memphis St-1000d
Used but in great condition. Has some scuffs but does not affect its performance
All measurements @ 14 volts unless otherwise specified:
Frequency Response (4 Ohm IHF Load 80 Hz Ref. Crossover @ highest setting): +0 dB, -.9 dB (Crossover -3 dB @ 249 Hz)
L/R channel error max deviation 20 Hz to 20 kHz: N/A
Signal-to-Noise Ratio (Below Rated Output, "A" weighted): -79 dB
Distortion at Rated Output @ 60 Hz: .4% @ 300 watts into 4 Ohms; .5% @ 500 watts into 2 Ohms; 1.1% @ 1100 watts into 1 ohm
Output Power (Resistive) (2 ohms @ 60 Hz to 1% THD+N): 791 watts @ 14 volts; 643 watts @ 12.8 volts; 231 watts @ 10.5 volts; 425 watts @ ***
Output Power (Resistive) (1 ohm @ 60 Hz to 1% THD+N): 997 watts @ 14 volts; 886 watts @ 12.8 volts; 246 watts @ 10.5 volts; 688 watts @ ***
Output Power (Reactive) (2 ohm IHF Load @ 60 Hz to 1% THD+N): 846 watts
Crosstalk @rated output, 20 Hz to 20 kHz: N/A
Damping Factor @ 100 Hz: 25
Voltage for Rated Output: 182 mV to 4.5 volts
Idle Current Draw: 1.7 amps
Current Draw @ 1/3 Maximum Power: 33.2 amps @ 332 watts
Efficiency @ 1/3 Maximum Power: 71%
Power-Up Noise: 51.3 dB SPL
Power Down Noise: 51.1 dB SPL
*** Output Power @ onset of clipping.
$200 obo
Shipping will through UPS
View attachment 26525235View attachment 26525236
TTT.
$160 shipped or I'm willing to trade for a nice 1000-1500 watt 4 channel, plus cash on my end if I have to.
ex. crescendo 1000c4, kicker Kx 800.4 or 850.4.
  • Locked
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
955
https://caraudiobargain.com/audio-apex-cab-22-car-amplifier-monoblock-2200-watts-rms/ Since these are back in stock they're really hard to beat...
973
And the most important thing you've learned in life up to this point is to get offended on behalf of other people on the internet in the attempt...
18
4K
So recently I bought a Memphis prx1000.1 and installed it to 2 rockfordfosgate r1s'. Both svc and 150rms 4ohm. I wired them to a 2ohm load to the...
flaboy22
flaboy22
Central Florida
flaboy22
    May 18, 2024
    May 18, 2024
