Memphis 16-ST1000D
flaboy22
Memphis St-1000d
Used but in great condition. Has some scuffs but does not affect its performance
All measurements @ 14 volts unless otherwise specified:
Frequency Response (4 Ohm IHF Load 80 Hz Ref. Crossover @ highest setting): +0 dB, -.9 dB (Crossover -3 dB @ 249 Hz)
L/R channel error max deviation 20 Hz to 20 kHz: N/A
Signal-to-Noise Ratio (Below Rated Output, "A" weighted): -79 dB
Distortion at Rated Output @ 60 Hz: .4% @ 300 watts into 4 Ohms; .5% @ 500 watts into 2 Ohms; 1.1% @ 1100 watts into 1 ohm
Output Power (Resistive) (2 ohms @ 60 Hz to 1% THD+N): 791 watts @ 14 volts; 643 watts @ 12.8 volts; 231 watts @ 10.5 volts; 425 watts @ ***
Output Power (Resistive) (1 ohm @ 60 Hz to 1% THD+N): 997 watts @ 14 volts; 886 watts @ 12.8 volts; 246 watts @ 10.5 volts; 688 watts @ ***
Output Power (Reactive) (2 ohm IHF Load @ 60 Hz to 1% THD+N): 846 watts
Crosstalk @rated output, 20 Hz to 20 kHz: N/A
Damping Factor @ 100 Hz: 25
Voltage for Rated Output: 182 mV to 4.5 volts
Idle Current Draw: 1.7 amps
Current Draw @ 1/3 Maximum Power: 33.2 amps @ 332 watts
Efficiency @ 1/3 Maximum Power: 71%
Power-Up Noise: 51.3 dB SPL
Power Down Noise: 51.1 dB SPL
*** Output Power @ onset of clipping.
$200 obo
Shipping will through UPS
View attachment 26525235View attachment 26525236
flaboy22
flaboy22
Central Florida
flaboy22
