slonoma00
Im sure there is already a thread about this but for some reason the search option is not working for me. My setup is a single 12" alpine type r pushed by a kicker zr360 and controlled by a eclipse cd-5455 headunit. I am having problems melting the fuse holder. Im running a 50 amp fuse which from what i know is about right for my setup. My amp has two 20amp fuses so ten up from that is 50amps. I was told i am pulling to many amps and i should upgrade my wire in size but my amp only accepts 4g wire. Should i go with a anl inline fuse setup to handle the heat better? I mean with it melting the fuse holder, would it be safe to do this change or do i need to look elsewhere for my problem. Any answers will help seeing i dont know where else to look. Oh, and its not subject to heat from the engine, the terminals seem to be melting right through the plastic.
