Melodic Acoustic Euphoria set
crxsir121
High End Car Speakers. This is the Euphoria set. In mint condition. Includes .75inch tweeter and 3.5inch midrange. Bought these from a fellow Diyma member, but never got to install them=( These were installed in his Lancer. Awesome set for kick panel or A-pillar install. This set is $540 brand new. Asking $325 for the 4 piece set. No Trades. Only selling due to money needed for my turbo upgrade. These are my pics from DIYMA.com. If you need more I can take more pics.
More info below:
Store - Authentic to the Music
404 - Page Not Found
This 2-way arrangement consists of the following Euphoria series transducers, the Euphoria 2.0 High Frequency Transducer, the Euphoria 8.9 High Accuracy Wide-Band Mid-range Transducer. Just like ebony and ivory on a Baby Grand Piano they live together in perfect harmony!
Now a deeper look at the co-conspirators that make up the standard setting Euphoria Duet:
Let's start with the work horse of the group, the Euphoria 8.9 high accuracy wide-band mid-range. Every design aspect of the Euphoria 8.9 was done to improve its linearity, from the ceramic massive 70mm motor structure , to the outstanding suspension that allows the Euphoria 8.9 3mm of one-way excursion. Now consider the remarkable 3 layer Paper cone, high grade copper voice coil by way of Denmark and copper sleeve, ever feature of the Euphoria 8.9 ensures nothing short of stellar performance. With extension down into the mid-bass region, some may say that the Euphoria 8.9 is a exquisite, harmonious, and graceful brute. Simply put the Melodic Acoustic Euphoria 8.9 was designed to render your music with a sense of emotion and naturalness that envelops you into the musical experience. Euphoria 8.9 is sure to set the benchmark for all other small format Wide-Band mid-range transducer to be measured by.
Rounding out the irreproachable twosome is the Euphoria 2.0 high resolution high frequency transducer. Here is an amazing quote by John Wooden; "It's the little details that are vital. Little things make big things happen". That just seems like the perfect quote to describe the Euphoria 2.0. As the quote implies this amazing little songster makes big things happen as it breaths life and airiness into this duet. Employing an Alloy dome mated to a silk surround and a high grade 20mm voice coil the Euphoria 2.0 without question can only be describe as high resolution, accurate, revealing, and smooth and lavished with detail.
This amazing duet is considered as true acoustic listening arrangement, true in the literal sense of the word, meaning that this duet remains linear at all listening levels. Everything about the Euphoria Duet implies dynamics, musicality, and linearity, from the massive and imposing ceramic motor on the Euphoria 8.9, to the beautiful alloy dome on the Euphoria 2.0 and from the first glance you will know that the Euphoria Duet have arrived and they are all business. The business of authentic music reproduction!
Item(s) Description/Condition: Mint
Price: $325
Shipping and Miscellaneous Item Information: Included
crxsir121
crxsir121
San Diego, Ca.
crxsir121
