mechman vs singer alt
Mechman vs Singer Alternator
  • Mechman
    Votes: 0 0.0%
  • Singer
    Votes: 12 100.0%
  • Total voters
    12
mechman-425 shipped 240 amp 2 year warranty
singer 469 shipped 250 amp lifetime warranty
$44 more for 10 amps more. Have to decide for yourself if that is worth it to you. I'd say it would be if you actually get that extra 10 amps. A few things I would check to help your decision:
1. Make sure it is a direct bolt-on so you won't have to have a bracket made.
-Simply as stated
2. Find out if the upgraded alternator is in an OEM case or if it is a 3G or even 4G case.
-This has positives and negatives... an OEM case will be the same size, fit, and bracket with no worries. However OEM cases are meant to dissipate the heat of OEM components; as in your stock alt that pushes ~100-150amps depending on car. The case might restrict heat dissipationfor the H/O components and decrease it's life and output due to the temperatures.
-On the other end, a 3G or 4G case would be beneficial, and will most likely bolt right on too, but if it is a tight fit with the OEM case, the bigger case might not fit.
3. Find out the regulator that will be used (What voltage it will run at)
-If you are going to use AGM batteries such as XS, Kinetik, etc, you don't want to charge them above 14.8v . It will cause the batteries to expand. Not good even for the car electrical if it is sensitive.
4. Find out what each has for idle output and what actual ENGINE rpm you will see that number.
-I don't know what vehicle you have but if it's a smaller car and you idle around ~600rpm, you don't give two shits about a idle rating that is for about ~900rpm such as on a truck.
5. Find out what engine rpm the max output will be obtained.
-I've gotten quotes for an alt years ago when searching for my first car that obtained max output at 2,400 engine rpm... when the hell, besides flooring the car from a dead stop, would I ever see that.. oh.. NEVER!
Just a few ideas to look into as well. I've heard great things about both Singer and Mechman. DC power is a bit more expensive, I just ordered my alt from them last week. Just weigh the positives and negatives and you will figure it out //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Good luck!
-Simply as stated
240 amp
500 rpm turn on
650 rpm - 100 amps
800 rpm - 140 amps
1500 rpm - 240 amps
$399
casing comes off of a 09 malibu they use. talking with mechman they also said since my car is heavily modified and since it idles at 900ish. has a large stall and cruises at 80mph at around 2700 rpm and shift points between 6700 and 7000 with a limiter at 7200 that i would benifit from an overdrive pully so i dont destroy the alt vs the typical underdrive that most dealers put on. he said the overdrive pully is very close to the stock size pully
240 amp500 rpm turn on
650 rpm - 100 amps
800 rpm - 140 amps
1500 rpm - 240 amps
$399
Oh good, those are solid specs. Well comes down to your call man. I don't think you would make a mistake either way. Correct me if I am wrong but a overdrive pulley has a smaller diameter so it would actually turn faster than say the larger stock pulley. So with the high rpm shift points, wouldn't the overdrive pulley be a bad idea?
yes he said he recomends putting a underdrive lol sorry. its a little bigger than a stock to slow the alternator down because at shift points of 6700rms could be hard on any alternator he said
Ah okay, I figured you mispoke lol. Probably would be a good idea then! Well now just compare singer's specs if you asked him.
mclerico83
mclerico83
tampa
mrclean636
