Mechanics help?
Blados
So my yukon is doing something interesting. It has front and rear air. The front driver's side air is blowing hot (2 vents), all the rest, front and back are blowing cold as they should. The only thing I did was disconnect the battery yesterday, and I can't imagine that has anything to do with it. Any idea what it might be?
do you have the driver side vent open (as in outdoor air comes in from those vents?) if so you have to close it...if not then play with the airflow switch...and see if it comes in...if not then you have a problem in which the ducts are getting blocked from getting the ac..
No all air is coming from inside. What do you mean by airflow switch? The air blows fine, it's just hot.
to switch it from floor to defrost to head to both floor and head...play with that....the door should start to work....
Air started cold, then went hot after 5 seconds. Then I tried this and it worked. Is this a temp fix or should it be fine?
Blados
Blados
Baltimore
cj407
