measuring a trunk
  • 4
kegan
Alright I want someone to build me a box, but first I need to know what I need to measure in my trunk. I have a 96 nissan altima, normal trunk pretty decent size... Do I just need to measure width,length and height to where it will fit in the trunk, and then get someone to put those numbers in a program for me to get the dimensions on a box?
Also for im wanting SQ with decent,low hitting bass. Would 2 15s or 1 18 be better suited for this?(the fi q's in particular)
you want to measure height trunk top to floor/false floor, trunk width between the trunk lid bars, and depth from backseat to trunk opening. Then you want to measure the actual trunk opening because if the box doesn't fit in the opening it doesn't matter if it physically can fit inside the trunk (cause you wouldn't be able to get it in there).
btw you'll have a hard time fitting a ported 2 15 or 1 18 box in that trunk
What would you suggest then? I want something to hit the lows **** good, but other then some decent bass I dont need my vision shaking from it... And I will be going with FI and probaly the Q's.. Would 2 12's be good?
hitting the lows isn't all about driver size, its more about box tuning. get whatever fits, just tune it low
Alright ill measure tonight and im sure someone can use the program to lemme know whats gonna fit.... 28hz is a pretty low tune isn't it?
Try this other test; get a 3.5mm headphone repair cable and connect it to the LC7i input. Connect that to your phone and measure. This will tell...
887
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
723
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
kegan
kegan
soddy daisy TN
thegreatestpenn
    May 16, 2024
    May 16, 2024
