Measurements for ext cab S10
skullsmasher
ca
If anyone has some please post em up so I can compare.
I haven't made the port measurements yet but here is what I have so far.
3/4 mdf:
45"x27"
45"x7"
45"x15"
45"x3"
45"x8"
Does anyone have suggestions or any comments about this size of a box for a couple (Maybe 3) 12"s ?
What should I use to prevent rattling if any occurs? Where should it go usually? I know it depends where it rattles from but, I am just not sure how to do it so any help is appreciated. Should I bolt it to the cab?
You can actually make the width 46.75 inches.
Keep in mind there is a jack stand that you may have to cut out.
Also, if you don't want it to go higher than the carpet on the back, your measurement is 12.5
Cool, thanks man. I was actually gonna go all the way up to just below the windshield so I can add 1-2 more woofers when I am able to.
the box is gonna be ok though if I just "throw it in there" ????
tryin to do this
Here is a box Chris (IonSQL) designed for a 99 ext cab s10. I will start building on this today probably. Should be fun.
cool, i need the measurements for the lip....the part where the floor bends or whatever.
Well, you know how that is. Growing up my father would refer to it as a "bug up ones arse", get the bug, you're an arse until it's satisfied! As a...
10
You can raise the back sea approx 2 inches and get a front firing enclosure for two tens in there ported center. Other than that. Atrend makes a...
On a sealed sub box if I faced the subs up, I lost quite a bit of bass. Faced them forward, they worked great. On a ported box with subs and...
You could fit 2 SVC Dayton HO 10's ported behind that seat no problem.. You would need a amp that puts out power at 2 ohms.. If you had bucket...
14
skullsmasher
skullsmasher
ca
skullsmasher
    May 12, 2024
Brendon Jenness
    May 11, 2024
