mb quart dsc 2000.1
awwwwwww butthurt? call them and talk to the engineer. it isnt recommended but it has been tested and their were no issuesask Mike Hughes how low he runs his dsc amps //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif you would shit your pants //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
how bout you use the search feature as well noob there are threads on here about it that i didnt start from people that are doing it //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
seriously, those cheap *** amps won't putout 3kw they barely putout 2kw..
your not going to argue this i hope..
just like those strong 4500 watt DD m3s huh?
seriously, open your amp up and give me part numbers ill show you what i mean..
ive never seen a group like this one..you want to run that amp below recommended impedance for what?
the DF is already piss poor..
Nobody has ever run an amp below recomended impedance before?? LOL
I read from sicaudio (though I dont take his advice seriously) that alot of people had been running them with success @ .5
I want to wire it to .5 *if possible* but after rise Im sure itll be higher, but I want reliability
sure get that maxxsonic board.. its a sure winner... seriously they have much better stuff on the market.. no need to drop impedance that low.. current goes through the roof and most power supplies aren't built for it.. many people have luck bescuse there box and woofer have a high impedance rise... not all alignments react the same.. your better off getting something like hte sundown 2k running it @1ohm.. they do about 2500@1ohm.. so does the DAT HF2500D much better amps..
As I've stated multiple times, I DO NOT RECOMMEND RUNNING ONE AT .5 OHM.
They aren't built for it.
I burp mine at 1 ohm strapped, but will never run them at .5 daily.
But even if they only do 2kw, that's 2kw for $275 shipped from an authorized dealer. No other company can touch that price-to-power ratio.
I saw a clamp test on one and it only did a few watts above rated. Nowhere near 2500.
BTW...
Saints owned that *** tonight. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
BIGTOSH
BIGTOSH
ric,va
Qxxx4
