mb quart dcs2000.1 vs autotek mm2000.1
the dsc is quite a bit more efficient especially at 12 volts but the mm will take 16 iirc they both do about the same power iirc and the dsc has a lower thd
Can you post the efficiency ratings and thd levels? Sorry I'm a little busy
WTF im sorry guys but the MM is much cleaner, yes it is less efficient.. the mm2000d is a tad bit stronger as well... the MB is basically a knock off of the HIfonics 2k.. you can find a used RD 1750 or SD 1500 and you will be happy...
whats your budget? what woofers you have? what typr of electrical system you have?
powerbass makes excellent budget amps so does audioque
WTF im sorry guys but the MM is much cleaner, yes it is less efficient.. the mm2000d is a tad bit stronger as well... the MB is basically a knock off of the HIfonics 2k.. you can find a used RD 1750 or SD 1500 and you will be happy...whats your budget? what woofers you have? what typr of electrical system you have?
The DSC2000.1, MM2000.1, and 2010D are all made by maxxsonics. They are all very, VERY, similar in build quality and output, if not exactly the same.
I agree with paper. The MM's are beasts and ive heard of the old ones being dropped to .5 or even .25 without problems(not daily). Imo they are a better build amp. The MB is just a new boner on the forums so everyone without knowledge rides the dick.
look idoit.. im tired of telling your rejects this stuff.. its has more parts so it must be better.. WTF? you know how many different types of transistors and caps they have out there? the MM2000.1 is decent at best compared to the stuff out now.. you want to believe that do so, but if you talk out your *** im going to make you look stupid.. ESP when im taking time to try and help someone else spend there hard earned money on something people actually took time to design test build and back,,,
deathpenalty18
get r done
deathpenalty18
Florida
corrie32
Old_risk
    Jun 23, 2026
Old_risk
    Jun 23, 2026
