MB Quart & Phoenix Gold Amplifiers 2 & 4 channels
Vertex Audio
Pro Seller
Supporting Vendor
Couple unique amps for sale.
1. MB Quart NSC 2100 2 channel
2. MB Quart NSC 475 4 channel
3. Phoenix Gold SD 800.4
MB Quart NSC 2100:
2-Channel Class A/B Amplifier
2 x 100w RMS @ 4
2 x 175w RMS @ 2
1 x 700w RMS @ 1 ohm
HP 15-250 Hz, LP 30-250 Hz
205 x 50 x 275 mm
MB Quart 475
4 x 75w RMS @ 4 Ohm
4 x 125w RMS @ 2 Ohm
2 x 250w RMS @ 4 Ohm
HP 10-150 Hz, 2 x LP 30-150 Hz
205 x 50 x 275 mm
POWER RATING
200 watts x 4 channel / 2 Ohms
125 watts x 4 channel / 4 Ohms
LOW PASS RANGE
40Hz to 400Hz
LOW PASS SLOPE
12dC/Octave
BASS BOOST
0 to +18dB
POWER TERMINAL
4GA
FREQUENCY RESPONSE
20Hz to 20kHz (+/- 1dB)
SIGNAL TO NOISE RATIO
Greater than 100dB
HARMONIC DISTORTION
Less than .1%
EFFICIENCY
80%
DAMPING FACTOR
Greater than 200
HEATSINK THERMAL MASS
5.0 grams per mm
DIMENSIONS
11.0" L x 6.9" W x 2.0" H
Amps are in used condition with minimal scratches and signs of wear.
1.$195 shipped
2.$195 shipped
3.$235 shipped
Included
Vertex Audio
Pro Seller
Supporting Vendor
Vertex Audio
Los Angeles
Vertex Audio
michigan born
    May 14, 2026
michigan born
    May 14, 2026
