MAZZASEC Another new build thread!
its all in the box... anything is possible... BTW my amp was at 1ohm with a rise to around 2.2 last time i checked it
how fast does impedance rise take in effect? My MM4000 is wired to 2.1, so after rise its probably 3 or 4 ohms since my wall is 9cf net. im assuming it increases when the volume increases?
Eventually i want to find subs that give me a final load between 1 and 1.4ohm, so with rise i should be just over 2 ohms (where the amp is "stable")
oddly enough I have found with a smaller box the more impedance rise I had
thats how it goes\
larger box, less impedance rise
smaller box, more rise, sharper curve
That's not really true. In a ported system, there will be two different spikes. Their relative peaks will be determined by the tuning frequency. Their distance away from the tuning frequency (in Hz) will be dependent on enclosure volume. The smaller the box, the further away the spikes occur from the tuning frequency and the larger the box, the closer they are to each other and the tuning frequency.
It makes sense if you think about it. The impedance spikes are due to system resonances. If you make a box larger, or lower the spring force, resonance will happen at a lower frequency. Think about IB systems too. In a first order system like IB, there is only one impedance spike that will occur around the Fs of the driver. If you take a ported enclosure and make it infinitely large, you will have an IB system with only one resonance (port tuning) as the two peaks will converge.
skip do u have a vid of u doin 154?
Nope //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Got USACI record for Louisiana with a 156.1 though on the net //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
time to go back to the lab then isnt it.
LOL Almost. Now just awaiting a box and batteries then everything will be a go //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif:D:D
mazzasec
Banned
mazzasec
ATL
mazzasec
