matching jbl gto ez amps 804 and 501
  • 2
stopdrpnro
gto804ez +gto501EZ amps
Item(s) Description/Condition: in good shape 804 has a scuff that's hidden by the shrouds, have to find a few replacements screws but amps are 8/10 cosmetically and 10/10 functionality. very clean and underrated amps 501 does >800 wrms on amp dyno
specs are
804
80 watts RMS x 4 at 4 ohms (100 watts RMS x 4 at 2 ohms)
200 watts RMS x 2 bridged at 4 ohms (4-ohm stable in bridged mode)
frequency response: 20-23,000 Hz
Class AB amp technology
variable low- and high pass filters (40-220 Hz, 12 dB/octave)
variable bass boost on rear channels (0-12 dB at 45 Hz)
Simple Setup System with test tone CD for perfect gain setting
routing switch for 2-channel sources
preamp outputs
preamp and speaker-level inputs (speaker wire-to-RCA adapters included)
switchable automatic signal-sensing turns on amp without need for remote lead
fuse rating: 25A x 2
8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
11-15/16"W x 2-5/8"H x 9-11/16"D
501
mono subwoofer amplifier
350 watts RMS x 1 at 4 ohms (500 watts RMS x 1 at 2 ohms)
CEA-2006 compliant
frequency response: 10-280 Hz
Class D amp technology
variable low-pass filter (40-280 Hz, 12 dB/octave)
variable bass boost (0-12 dB at 45 Hz)
optional wired remote level controller available soon
8-7/16"W x 2-3/8"H x 9-11/16"D
Price: 250 shipped for the pair
included
Im sure you could find a great deal on here as well for your mids and highs. Just another great speaker to be considered. Audio Frog may be...
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
looks like it will work just fine. this amp would work just as well if you want to save a little money. I run one of these and a 2k as well. Both...
2012 Seat Alhambra Deck: Grundig GX-3800 (already unhappy with this and planning to switch it out for a Kenwood unit) Door speakers: Kenwood...
19
stopdrpnro
stopdrpnro
durham ,nc
TreyE
    May 20, 2024
    May 20, 2024
