matching jbl gto ez amps 804 and 501
stopdrpnro
gto804ez +gto501EZ amps
Item(s) Description/Condition: in good shape 804 has a scuff that's hidden by the shrouds, have to find a few replacements screws but amps are 8/10 cosmetically and 10/10 functionality. very clean and underrated amps 501 does >800 wrms on amp dyno
specs are
804
80 watts RMS x 4 at 4 ohms (100 watts RMS x 4 at 2 ohms)
200 watts RMS x 2 bridged at 4 ohms (4-ohm stable in bridged mode)
frequency response: 20-23,000 Hz
Class AB amp technology
variable low- and high pass filters (40-220 Hz, 12 dB/octave)
variable bass boost on rear channels (0-12 dB at 45 Hz)
Simple Setup System with test tone CD for perfect gain setting
routing switch for 2-channel sources
preamp outputs
preamp and speaker-level inputs (speaker wire-to-RCA adapters included)
switchable automatic signal-sensing turns on amp without need for remote lead
fuse rating: 25A x 2
8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
11-15/16"W x 2-5/8"H x 9-11/16"D
501
mono subwoofer amplifier
350 watts RMS x 1 at 4 ohms (500 watts RMS x 1 at 2 ohms)
CEA-2006 compliant
frequency response: 10-280 Hz
Class D amp technology
variable low-pass filter (40-280 Hz, 12 dB/octave)
variable bass boost (0-12 dB at 45 Hz)
optional wired remote level controller available soon
8-7/16"W x 2-3/8"H x 9-11/16"D
Price: 250 shipped for the pair
included
stopdrpnro
stopdrpnro
durham ,nc
TreyE
