Snail
To preface, I come from the professional audio field doing installations in facilities like churches and such. The commonly understood method to matching amps and speakers is to use an amp to deliver twice the power that the speaker is rated at. In car-audio speak you would give a 40watt speaker an 80watt amp (and all of this is, of course, relating to average or "RMS" power). What I'm trying to create discussion on here is efficiency; really driving a speaker for all that it is safely worth, without straining the amplifier. I'm talking about everything from tweets to subs BTW.
Generally, from what I've read and using this and other boards search function, car audio doesn't work the same way (or does it and it's just not common knowledge?). It seems as though the consensus is to give a 40watt speaker 40watts of amplification. My dilemma is that I've seen tidbits leaning very much to the "double it" idea in referance to mobile audio, and for the same reasons it is the norm for professional audio installs: "Doubling It" results in cleaner sound and amps that don't clip if done correctly. Of couse if you actually use 100% of the amp and put double continuous power to a speaker over a given period of time (depending on the quality of the speaker build, among other things) the power will physically overdrive and damage it.
So I'm wondering: The major difference I see here is the "professional" aspect of the professional sound reinforcement realm. For the most part, the system is set up by people who know what they're doing. The person behind the sound-board controlling the output, if they have any idea what they're doing with the gains on the board, would have a difficult time damaging the speakers.
This is of couse very different when you have Joe-Schmo throwing a car system together. All the online guides have to account for the lowest common denomenator right? Especially in our sue-happy society, I'm not going to take something like the Crutchfield matching guide as gosphel.
Bottom line: I'm sure we can all agree that, generally, matching a speakers technical handling capability very closely to what an amp actually delivers is a can't-go-wrong recepie. Of course if the user doesn't set up the system correctly or constantly drives the system into distortion, even the most perfectly matched system would have a dramatically shorter life span.
Please submit links to help me see the application of (or recommendation against) "doubling-it". Setting me straight, other theories and whatnot are welcome, but to the best service of the intention of the thread, please use real-world proof of what you believe to be true. Again, the general concensus is to match power desired to power given.
Thank you for reading my book and for any replies.
