Massive audio ct2 tweeters
riddla
nf
Hello all. Ive just bought these and im running an active setup. I wanted to know if i should use the cap / crossover that came with these. I also have a pioneer GM-D864 4 channel amp. Should i also set it to hi on the crossover or full range. My 3 way active crossover will separate the freqencies but just need some advise on the best set up. Thanks
no that would result in a much steeper slope because you have two crossovers in place. Just use your active crossover.
Thanks. What about the amp crossover settings. Full or hi pass
full. Everything done on the head unit/DSP
Ok ill do that. Ive always ran it on hi pass in the past on the amp as i always thought it would offer more protection but ill try it your way
my bad, it doesnt hurt to have a high pass on the amp for tweeters but for mids, definitely all head unit/dsp.
Ok . So no in line tweeter crossover. Done. Mid amp on full . Done. Headunit on normal / full. Done. Ill tune it up and see how it sounds.
All set up. Talk about sweet sound. These tweeters sound beautiful paired with my id oem 6.5in mids. 2 pioneer premier champion series subwoofers in ported box. Sounds lovely.
riddla
riddla
nf
riddla
