Marbel on a box?
By you saying it's not that hard, I'm going to assume you've never cut through stone ever. I say that because you can't just "rent" a wet stone cutting saw/grinding wheel, they are extremely expensive, let alone even more difficult to polish to a flawless finish.
http://www.granitecitytool.com/showitem.cfm?itemnum=340&catnum=0&pcatnum=80&n=Dia-Pro%20200%20ECO%20Semi-Automatic%20Stone%20Saw
http://www.granitecitytool.com/showitem.cfm?itemnum=1498&catnum=0&pcatnum=80&n=MK-312%20Wet%20Cutting%20Tile%20&%20Stone%20Saw
Like I said.
I had my marble cut on a 20' wide 6" concrete topped X/Y translation table with water cooled 24" diamond tipped blade and water / glycol cooled. I was covered in super fine marble mud when I was finished with it. Cutting marble aint no joke //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
cutting angles is even MORE fun //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
oh and btw the chick in the pic behind my score is a MECA judge at DB Drag Finals / KY State
Great time, innit? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
That sure looks like a good reason to me //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
lol, i was beeing sarcastic
Like I said.
haven't cut marble but i cut masonry brick to lay for my pool deck ill just take your word that it's hard
Not to mention Marble is friggin expensive. If you made a wrong cut it very well could make baby jesus cry.
But if you want granite and you have friends that own a granite countertop shop and have scrap out the *** it wouldn't matter a bit how much you screw up... //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
Snoopdan was wondering though why did you put the marble in the box?
Marble is naturally a very dense and its properties are basically acoustically reflective, as it does not absorb sound waves very well (as you might of probably notice if you've ever yelled in a marble hallway). The purpose of its use in this application was to funnel as much energy thru the horn as possible vs. absorbtion thru the MDF outter shell. Additionally, since the surface of the marble is glasspeened when produced, its a super smooth laminar air flow surface for the air to glide over when moving thru to the horns' port mouth. This reduced the need for resining 3/4 of the enclosure. I also needed to have a box that fit below the window line in my jeep and overall be small in size (4.5 cubes total) but still have enough space for an 18" and its basket. For specific and detailed pictures, check out my thread here : http://video.snoopdan.com/teamdailyforum/viewtopic.php?t=19 on the Team Daily fourm.
Octavio
Octavio
Nic
PV Audio
