man i feel like an idiot
alright cool. what do i do with those extra hanging wires tho?
quote:
i have these wires left:
power antenna
dash light/allumination
dimmer ground
amp turn on
then on the head unit one i have system remote control which is a plug type of thing i think
and can i chain grounds? ie can i jus solder all the ground together? and can i use if there is one the ground that the stock hu used?
no i mean the wires i have nothing to connect to. all of these
power antenna
dimmer ground
amp turn on
and then can i jsut chain all the grounds together
If your car doesnt have a power ant. dont worry about that one just tape up the end or use a cap to cover it so it doesnt touch anything.
If your not running a amp just do the same with that wire . If you have no wires to hook the other two with just do the same with those. Dont know about chaing all yor grounds together.
ok so i got a new Hu and a dash kit. I can slide by HU in the dash kit but for the life of me cant figure out how to lock it into the dash kit. i feel such like an idiot. any help? unit is a deh p4000ub if that helps
I have the same deck and had the same problem, I ended up gluing it in place with aircraft-grade two stage epoxy that we use at work... has worked fine ever since //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
is htat right?
revention
revention
houston
john denver
