making kerf cuts to bend a radius
Yep //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Take the circumference of the outside of the MDF board and the circumference of the inside of the MDF board in the bend (assuming the bend is a quarter of a circle, finding the circumference of the circle theyd be a part of) and devide them both by four and see what the difference is between the two (this is how much material needs to be cut away)....then see how much length of the board youre using for the bend and see how many blade-widths (minimum) it'd take to make the bend and devide the space on the board by that and mark them evenly spaced //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif...I kinda lost myself...but I think that's about how it goes //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
That almost makes sense, but I swear I felt the wax fly out of my ears as I read it.
I'll give it a try. Seems like once I have the amount of material to be removed, I divide that by 0.125 (thickness of the blade), then by the amount of board needed to make the radius, (which would equal the outside radius measurement) and I should come up with the spacing measurement. Thanks!
um... might not be a pro.. but i gotta ask.. whats the radius for?! lol my experiance is that all you need a cut that reduces the mdf down to 3/8ths of an inch every 5/8th of a inch. logically, you want enough curfs to let the boad not only bend, but to do so evenly. if you need more bend... yellow glue and laminate 3, 1/4 inch mdf.
If you were asking me 'whats the radius for?'...it's so you can figure a circumference of the bend...so you can make a calc on how much material needs to be cut away in order to make the bend //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
870
I had this same issue with my Sony. When I first got it I had speakers hooked up to the head unit without amplifiers and it worked fine. Once I...
Looks like half a dozen other makes/models on the market, rebranded . The shallow mounts look like they’re made by Pioneer but what the hay, one...
I think it worked .just odd bc it's brand new but I appreciate it man. haven't had any problems yet
Is that speaker in the existing rear deck? Are you running a sub in the trunk?Do you have that speaker on an amplifier?Are you using a stock HU...
sctattooer
Maker of Mischief
sctattooer
Myrtle Beach, SC
Pioneer~Saturn
audiobaun
    May 19, 2024
    May 19, 2024
