Alrighty, on to part two: transient quality. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The best way to get into this is to briefly describe how a loudspeaker actually works. As you know, you have a positive and negative input which is connected to your amplifier which is connected to source material. When that signal goes into the positive and out the negative, a few things happen. First of all, if you don't like mathematics then I apologize, but it's important to understand. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Now, there's something known as Faraday's law, which states that the change in the magnetic flux of a coil is equal to the voltage across it. This is very important for us, as speakers work on an electrical property called inductance. What happens is that when you run a current through a wire, a magnetic field is created that surrounds the wire. More importantly for us, when you take said wire and create a coil out of it, then you get what is called an inductor. Inductance is the property where when a current is flowing through a circuit, if you change that current, then the circuit will create a voltage that opposes that change. Now, your speaker has a voice coil which is simply an inductor wound on a piece of metal called a former. When you run a current through the voice coil, it creates a magnetic field around it, and when you consider the strength of the extent of the magnetic field, then it's what is called magnetic flux. Now, if we go back to our faraday's law, we can see that the higher the voltage that we put across that coil, the larger corresponding magnetic flux. //content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
As you likely know, magnets have a positive and negative polarity, and the same is true for coils with current running through them. The polarity, however, depends on whether the input is positive or negative. So, if you run a song's signal through that coil, you'll get rapidly changing positive and negative polarities. This is beneficial for us because your speaker has a large magnet attached to it which is appropriately called the motor. The magnet, on the other hand, can NOT change polarity. It is fixed and will always have the same polarity. Again, as you likely know, opposites attract and similar repels. Since your magnet has a constant polarity, and your voice coil is acting as an inductor and as the polarity of the magnetic field created by it changes from positive to negative, it gets easy to see that if you are going from positive to negative on a part that can move, and have a fixed polarity on another object, that means that the motor will therefore attract and repel the voice coil. That, is why your speaker moves: the changing magnetic field of the voice coil being attracted or repelled by the fixed magnet on the bottom of the speaker. //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
Now that the fundamental physics are out of the way, you're probably wondering why this has anything to do with how "quick" a speaker is? Well, if you stop and think about what I've said so far, if your speaker can change directions quickly as the signal passes through it, then it's going to be "quick". If not, then it will be "slow". How does that in any way have anything to do with the size of the cone? Therefore, you can see that how quickly a speaker can move is simply a function of the current running through it. If you take two speakers of the same make, but one is a 10" and the other is a 15", and assume that the only difference between the two is the moving mass, then how could that possibly affect how quickly the speaker responds? That change in mass is not at all going to affect how quickly the speaker can change directions! Consequently, if you make your motor larger, so that it has a larger magnetic field (called the B field), then you can increase the force with which the speaker can drive in and out. Also, if you increase the size of the inductor (most commonly done by length, although changes in diameter are possible as well), you can therefore also increase the amount of force. Finally, if you increase BOTH, then you can increase what is known as one of the fundamental parameters of all loudspeakers, called BL, which guess what: stands for the B-field, or the magnetic field, multiplied by the Length of the voice coil, which when multiplied with one another (B*L) is the parameter for the force that the motor can supply to the cone. //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
So, let's put it all together now, shall we? When we feed a current into the voice coil, it will attract and repel the fixed magnet which gives the speaker the movement. How QUICKLY it does this is due to mainly one thing: the inductance of the coil, as when you make it larger, the inductance goes up. So wait, doesn't that mean that smaller speakers which have smaller voice coils can respond more quickly? YES, it indeed does, which is why you don't see tweeters or midranges very often with incredibly large voice coils. The thing that you gain from increasing the size of your voice coil is power handling, or how much current you can feed into the voice coil before it burns to a crisp. So, you have to balance transient ability with power handling to make the ideal loudspeaker. Since we're talking about subwoofers, and subwoofers of the same make and same size differ ONLY by the size of the cone, not the size of the motor or the voice coil, then there is no way that a larger cone of the same make will be "slower" than one that is smaller.
Whew, hope that wasn't too technical, but if it helps at least one person understand why cone size does not affect its sound quality, then I feel I will have succeeded. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
-Dave
