Making a box for coaxial speakers and cant find any reccomendations from anywhere.
  • 2
nezz
Vehicle : bmw e30
Location in the vehicle: rear deck
Space available (Length x Width x Height): 60cm x 25cm x 10cm
Subwoofer make and model: Massive audio lx46
Subwoofer Size: 4x6
Number of Subwoofers: 2
Type of Port (Kerfed, Slot, Aero, etc.): ?
What type of music do you like?: Techno, rap, pop
Is your goal SPL or Everyday Music?: everyday music
Tuning Freq (Hz):?
Volume :?
Questions: Im not sure if im in the right place since its about subwoofers but il try my luck.
The reason why i want to build a box for them and not mount them in the rear deck is because i get to remove my old speakers and get some preassure into the cabin from the sub.
Hey there, your available space for a box is 0.52cu ft so its pretty small. I supposed given your speaker size of 4 x 6 inches, you could make a box , put a divider in between and make it a sealed enclosure. You may achieve an added thump in the mid-range / mid-bass region but nothing below those frequencies, I am afraid. Its not a subwoofer system that tiny as the enclosure would not allow it to generate bass regions, but if that's what you are chasing, then it should be ok. Also use a little amp with built in cross overs and you may need to tweak it to blend in to your front stage speakers.
740
I had this same issue with my Sony. When I first got it I had speakers hooked up to the head unit without amplifiers and it worked fine. Once I...
Looks like half a dozen other makes/models on the market, rebranded . The shallow mounts look like they’re made by Pioneer but what the hay, one...
I think it worked .just odd bc it's brand new but I appreciate it man. haven't had any problems yet
Is that speaker in the existing rear deck? Are you running a sub in the trunk?Do you have that speaker on an amplifier?Are you using a stock HU...
nezz
nezz
Finland
DRBOOM
    Apr 28, 2024
    Apr 28, 2024
