Make Sure I Got this Straight...
JRoc
I just bought an Alpine Mono V-Power amp that is 400W RMS x 1 @ 2 Ohms & 220W RMS x 1 @ 4 Ohms.
I have two Alpine Type E 10" subs that are 750W Peak & 250W RMS @ 4 Ohms.
So I'd be getting 220W RMS combined out of those 2 subs at 4 Ohms? Theres no bridging to do with this setup, correct? Is there any way I can hook up these subs & amp at 2 Ohms...or would that be dangerous or cause the subs/amp not to work correctly?
So basically 110W RMS per sub? Since the subs are 4 Ohm don't I HAVE to hook the amp up at 4 Ohms as well?
I dunno if this wattage would even satisfy my grandma.
umm...
you're going to be connecting the subs in parallel to the amp.
the amplifier will see a 2 ohm load...
each sub is still 4 ohms...
each sub will be getting half the power that the amp gives into 2 ohms...
the amp gives 400watts into 2 ohms...
each sub will be getting 200watts...
umm...
x2 on that //content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
Thank you so much. I am a noob at this.
I was thinking I had to wire the amp at 4 ohms since the subs were 4 ohms. That sutup wont harm anything will it?
I gotta find a site that tells how everything relates to one another (the sub ohms, the # of subs, the amp ohms, the # of amps, 1/2/3/4 channel amps, series vs parallel and the different ways you can hook up subs to an amp & what RMS wattage you'd get from diff setups) Thats what is confusing me. Mainly how the diff channel amps, the ohms & what wattage you'd get from the various setups you can do.
i put a pair of Type E 12's into a car w/500 watts last week.
it sounded pretty good //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
So that 200W per sub (400W total) would be the RMS, not the peak? And does Alpine overate/underate their subs? How many watts would you put into a type e 10" sub if you had one?
I hope its enuff to satisfy me. How much rms per speaker do you think a type E 10" sub can take before it clips/distorts/damages the sub?
Sorry to bring this back from he dead but I was wondering...
The 200W per sub (400W total) would be the RMS correct? Or would that be the peak watts?
JRoc
JRoc
CASHville
ultimate157
