mag bumpin..
The frame rate on your camera's video capture makes the sub look like it's just jumping around. I'm surprised that the audio is constant though - most camera's just get overloaded and don't record any of the sound.
I thought you were selling this sub a long time ago because you were unhappy with it?
Yeah, but i figured its gonna be about the best sub i can get in my application, i can't really go any bigger than 2.5 cubes in my camaro, so i just might as well keep it. I'm still not happy with it though. It's loud..just not loud enough. But this weekend im getting a nine.1 and running 1/0, eventually doing big 3 so we'll see how it turns out.
Yeah, i mentioned im going to upgrade amps. Did you mean better amp than the nine.1?
And if it isn't loud enough, it doesn't mean somethings wrong..It just means i have really high expectations.
No, try a better amp than the nine.1.
Pick up a used MD2 or something.
9.1 will be plenty of power. they are rated at what...1200rms? and benching at 1400. MD2 isnt going to be a major upgrade.
If you add the 1/0 and 9.1 and still aren't happy you probly wont find anything better in your camero. Maybe find 2 older XXX10's and hope that the added cone area makes up for the output you want.
f bodys are dead easy to get 4 cuft vb or so outta them...
I've did so many dual 12" installs in them I can do it asleep... and would rip your head off..
extremely easy vehicle to get wangin... got pics of the entire box, etc?
n/m.. watched the 2nd video on there... best to be firing directly up, not tilted forward.. and the port needs to go on the other side, for you....
Loyd L.
Loyd L.
Hum, i had it firing straight up before, didn't like it as much as this. And why would i need the port on the other side?......It's on the same side as me..is that bad? i could always turn the box around. I dont understand how you can get any bigger of box in there.......
Rated at 1200, benching about 1200 in a real world application. Not the cleanest power in the world either.
Ported, I think an MD2 would fare a little better.
slikrider20
slikrider20
Nebraska
CBFryman2
