Made a quick vid of my carputer in action
Randy Savage
Looks good man...what GUI is that you are using? Ive got Mediaengine setup on my carputer and found its sort of hard to use a touchscreen interface on a SPL vechile sometimes. I ended up getting one of those Targus trackball presentation pointers just so I could control the interface outside the vehicle.
Have you had any noise issues? Thats probably the #1 problem with carputers, either the power supply you use has intrinsic noise, or the soundcard has popping issues when initalized. I have good ole signal noise problems with mine - and had been considering a dc to dc converter buffer....is that something you considered as well or was your setup more plug and play?
I noticed that with the POS( not that POS) i have at work its not exact and is a few milimeters off when i use my finger. But with a pen its much eaiser.
Mouse , works the best
I'm using Road Runner...I tried Centrafuse but preferred Road Runner over that and I've been using that ever since.
As for the noise issues, I did have a problem with turn on thump, but my PSU has a turn-on delay that I hooked up to my remote line for my amp that solved the problem. Only noise I've had is a little engine whine through the Line-in for XM, but it's not bad at all. I've heard that with on-board sound cards this is a common problem, and upgrading the sound card will solve this. Eventually I will upgrade the sound card when I get around to building the sound system.
I noticed that with the POS( not that POS) i have at work its not exact and is a few milimeters off when i use my finger. But with a pen its much eaiser.Mouse , works the best
With Road Runner running I don't have that problem, as the buttons are pretty big. When I navigate Windows, however, I do have that problem, so I use a stylus for that.
Randy Savage
Randy Savage
New York
Randy Savage
