MA Audio SY1000L line driver
Used Missing cover
Some of the features include a heavy duty polished aluminum heat sink with a flush mount triple chrome plated top plate, removable rack handles, dual VU meters, gold plated terminals, adjustable input sensitivity, remote on/off, balanced outputs, 19k ohm input impedance and a switching power supply.
The frequency response is 10 Hz to 25 kHz with a THD of 0.05 percent. The unit measures 9.5 inches W x 6.5 inches D x 2 inches H and will fit into virtually any application. The majority of source units made today have less than a 4 Volt output. Many amplifiers today such as MA Audio’s High Current Series accept up to 8 volts of input. If you’ve got a high current amplifier or even a Class D or T amplifier, you need a Synergy line driver to make it scream and give it a full 8 volts of input.
In addition to being a great line driver, ease of use and convenience was also a primary concern. Top mounted VU meters are readily visible to aid in matching channels and balancing outputs and the gain controls are mounted directly below them.
$50
buyer pays shipping
https://post.craigslist.org/imagepreview/m/5Gf5H55M13Eb3Lb3H1c8d50263e9dbabf1a20.jpg
Used Missing cover
$50
buyer pays shipping
