MA audio subwoofer Specs
  • 2
bigd26
Toronto
I was wondering if anyone could help me, I am looking for the enclose specs for a MA audio hardkore 15 inch sub, competition sub from some years ago rated "5000" rms,
I have the specs for the kore 18, but looking for the kore 15,
Looking to build a new box
PARAMETERS
KORE 18
Fo (Hz) 33
QMS 4.98
QES 0.87
QTS 0.82
VAS (Liters) 28.76
REVC (Ohms) 5.2 (series)
SPL @ 1 watt / 1 meter (dB) 88.9
X-max Linear pk-pk (mm) 28
LEVC at 1k Hz (mH) 1.9
ENCLOSURE VOLUME'S SEALED
Minimum sealed (Cu. Ft) 1.75
Fill Required (%) No
3dB down point (-3dB Hz) 41
Maximum sealed (Cu. Ft) 2.5
3dB down point (-3dB Hz) 38
ENCLOSURE VOLUME'S PORTED
7 ftcu.
PORT SIZE 15 x 5 x 11.75
tune to fit application custom 42 HZ decrease legnth to raise freq.
SEALED 3 ftcu.
I may have just found some info
Diameter: 15 Inch
Impedance: 2 Ohm
Sensitivity: 90.6dB @ 1w/1m
Mounting Depth: 9 3/8"
Mounting Diameter: 14.2"
Vented Box: 5 cu/ft
Port: 48 sq/in 13.0" Long
Sealed Box: 2-2.5 cu/ft
Weight: 57 lbs.
box tuning, if I were to use a box around 5ftcubed and tuned to 32 hz, even though manufacture recommends 40 (i assume its recommending 40 at 5000 watts, im only putting 2000 in,
would that be alright, being in my first set up would I even notice a difference?
manufacture for a new version of my sub i couldnt find for my exact sub, same size and output though
5 Cubic Foot Optimum Enclosure: Vented 40Hz - (2) 5" round x 9.5" deep or slotted 10" x 5" x 9.5" 50Hz - (2) 8" round x 7"
just for a daily, i dont intended on competing, i mean I wish I could but I dont think 2000 watts is enough to compete
I got to message a DD woofer builder a decent bit my last stent of box designing; they would send me designs to do for or with individual...
The Biden administration on Tuesday backed down on a controversial proposal to direct the IRS to collect additional data on every bank account...
31
6K
Pick it off the floor while playing. If rattle goes away then it is fine. If not, bad sub.
I agree with AnthonyO. I use a lot of audiocontrol products the dsp is easy to use and with the acr3 you have a few different options on bass knob...
bigd26
bigd26
Toronto
bigd26
    Jun 15, 2024
    Jun 15, 2024
