MA Audio HK898
the_abbot
New here. Love the forum!
Question: I am thinking about picking up this amp to power my 2 12inch infinity subs (just for casual thumping). The subs can handle 600Watts rms.
Do I need to do anything special to my electrical system, or will it be fine to run at stock batt/alt,etc?
dont buy this amp. i have found it to be highly overrated. it puts out no where near its rated power. in fact i switched mine out to a RF punch 150 25-life amp off millionbuy from ebay. very underrated and im sure you can get it to work with your subwoofers voice coil configuration.
i dont remember the spec sheet but my amp only put out ~187 watts at 3 ohms or so when i believe the it should of put out close to 300 watts. so there you go. that amp is good...you just have to know the true wattage it puts out before you buy it so you can properly match it to the speakers you have. later
the_abbot
the_abbot
Florida
IgnoreMe
michigan born
    May 14, 2026
michigan born
    May 14, 2026
