now you must not know directed verry well the old 1100d amps put out 1500 wrms + benched @ 13.5 so it was over well 3000wYeah, it's funny to think that a sealed enclosure with only 2000 watts could possibly create enough internal pressure in the vehicle to cause enough flex to shatter a window. If there was enough flex it should break the window seal long before the window broke. Sounds more like there was another factor involved in the window shattering. I've seen plenty of windows break, and none were because of flexing, none were with a measly little 2000 watts and none were with a sealed box.
It's straight up, the worst.I have seen 2 MA 15s take and 802sx each. So yes there are MA subs that can take that amp. The amp isnt the worst and it isnt the best.
Definitely better. If you want many watts for cheap, try a used Kicker 2500.1, Crunch GP3000D-Pro, or something else.so is this a good amp to run 2 15 l7s or is there a better one in the same price range?
Please leave.now you must not know directed verry well the old 1100d amps put out 1500 wrms + benched @ 13.5 so it was over well 3000w
Says the man with the crunch amp.
Have you clamped your Crunch? Did you clamp the MA? I have clamped the MA to do 2k @ 4.![]()
My Crunch amp absolutely destroys the HK802SX. I had the MA on 2 G31 batts and my 200 amp alt. Voltage drops down to low 10 volts, and put out less than 2kW. My Crunch is running off a single, old red-top and the same alt. My voltage now doesn't drop below 12.5, and does SOOOOOOOOOO much more wattage.
sport??//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif:wow: //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gifi think your all jerks to the noobs on this forum... he don't know any better, but you all choose to make fun of him instead of helping him out... no wonder the sport is dying out...
Yeah, mkay.Have you clamped your Crunch? Did you clamp the MA? I have clamped the MA to do 2k @ 4.
It is, in fact, a sport. Look it up in the bassctionary.sport??//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif:wow: //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
