MA AUDIO HK4000D vs. SS PCA3500D
photocrazy8
Probably doesn't like you
Ok so i have (2) 15's that RMS at 1500 each. Coil config is Dual 1.8, so i could get a load of 1.8, .9, or .45 ohm. I am thinking about the MA AUDIO HK4000D or the sound stream PCA3500D. Im not sure how to figure in rise but i want them to get about 1500 or a little over after rise. My electrical will be dual 250 alts and 4-5 yellow tops and (2) runs of 2/0 welding wire. So i would like to hear some reviews for each amp, price is not an issue. I also want an amp that is going to work for a long time. This if for my daily driver....thanks guys, andrew
If price isn't an issue, look into either the Adassa Warlord or US Amps AX-3000DE
Edit; The MA Audio amp is rated @ 17 volts, so unless you're running that high, it won't put out 4k watts, also, I don't see many PCA3500D's around so I dont know how much information people will give you. They're priced to sell though @ around 650 and they look good too.
so i found out that the 20.1 will do about 2800 at .5 ohm which is not enought power for me so its going to be sold. Next i think the sound stream it out because people have had some problems with them and they are over rated. So its between the Lanzar which does 4000 watts at one ohm, which is close to my .9 ohm or the MA audio which does 3600 at 2 ohm which is close to my 1.8 ohm. i may try and get the MA modded to take the .5 ohm which is close to my .45 ohm //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
so after all that typing...MA or Lanzar?
y'all sure the 4000d does 4000 @ 1 ohm.....all the specs i can find are 2000 @ 2 ohm .....it looks like its not 1 ohm stable
i bet hes talking about the lanzar because he just bought one.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
ok good to know. also how much did he get it for and where?
photocrazy8
photocrazy8
CA
jeepintn
