Brand new, never seen power, they make rated power at 1ohm, comes with sticker, license plate, and extra fuses and remote gain knob. 275 shipped, only trade i am looking for is a amp that does 3000 watts plus cash on my part. i have refs too, if you need them pm me
here are the specs:
RMS Power @ 14.4V: 750W @ 4 Ohm, 1000W @ 2 Ohm, 1500W @ 1 Ohm
RMS Power @ 17.0V: 1000W@ 4 Ohm, 1500W@ 2 Ohm, 1800W @ 1 Ohm
Fuse Rating: 40A x 4
Dimensions (W x H x D) 12.4" x 2.71" x 14.29"
Temperature, Voltage & Output Level LCD Display
Thermal, Short & Overload Protection Circuitry
Platinum Plated Screw Type RCA Jacks
Double Sided Black Epoxy PCB Board
Platinum Plated Block Terminals
Fully Unregulated Power Supply
Stainless Steel Finish Heat sink
Quiet Fan Cooling System
Remote Gain Control
Full Mosfet Circuitry
Frequency Response: 10Hz - 350Hz
24dB Low Pass Filter: 50Hz - 350Hz
24dB Subsonic Filter: 15Hz - 50Hz
Variable 0 - 18dB Bass Boost Control at 45Hz
RCA Input Sensitivity: 0.2 - 8V
Low level Input Impedance: 22K Ohms
Damping Factor: 200 @ 4 Ohm
1 Ohm Mono Stable
here are the specs:
Remote Gain Control
1 Ohm Mono Stable
