ma audio 800xl specs
corbetjackson50
I just got a pair of these 8's and the box they cam with is a huge sealed box. I am wanting to build a ported or vented box for it . It should be 2 cubes but Im not
Sure what to tune it to? i like the low 30's but i think i remember the.recommended was like 43hz or something crazy. Any help appreciated
Im thinking about taking the easy fast and cheapm ethod and see what happens. The box the came with is sealed two chambers measuring 1.375 cubes each. Im not sure of the speakers displacement but i was thinking about slapping a 3" diameter port measuring about 9.5" which should give me 35hz. If i don't like it ill start from scratch. What do you think?
Subwoofer Specifications
Subwoofer Size 8"
Peak Power Handling 800 watts
RMS Power Handling 400 watts
Voice Coil(s) Dual
Impedance (Per Voice Coil) 4 ohms
Sensitivity 84.99 dB
Woofer Surround Ribbed Poly-Foam
Recommended Enclosure Specifications
Minimum Sealed Box Volume 0.25 cubic feet
Maximum Sealed Box Volume 0.5 cubic feet
Minimum Ported Box Volume 1.0 cubic feet
Maximum Ported Box Volume 1.0 cubic feet
Top-Mount Depth 4.6"
Cutout Diameter 7.3"
Well i tried something simple and put two 3.5 inch ports in the sealed box. This turned it into 2.75 cubes before displacement of subs or ports i tuned it to 34hz. I must say i am pretty impressed with these guys they are seeing about 1000w rms each lol but the bass knob stays below half way.
corbetjackson50
corbetjackson50
lexington KY
corbetjackson50
