PowerBass 3XL-152D
Follow the owners manual to a T and you will love this sub. Break it in like they recommend, Build the box to the specs they recommend, as they recommend (bracing, etc). Power it with a clean, solid 1000 watts and it will get down on the lows and do very good work for you. If you want a strictly spl set-up, call powerbass cs and tell them what you have and what you want to do with it. CS can get you in contact with a couple of guys that use them in comps that will answer your questions and will recommend spl box dimensions.
http://www.powerbassusa.com/sites/powerbassusa.com/files/3XL_Woofer_Manual%20v2_0.pdf
My trunk cant fit a 4.5cu.ft box so i have to go with 3.5cubes @ 32hz, other than that i got it all set. Audiopipe APSM-1500 is the amp.
Box is 3.25 cubes @ 32hz
This thing LOVES lows, but its highs are meh. Its still breaking in and ive already noticed a bit of improvement.
I'd also like to mention my amp, the AudioPipe APSM-1500 is pushing this thing rated 1000W RMS very good. The audio shop that installed this wouldnt think that little amp would push the sub a lot. Wired down to 1ohms (1.3ohms box rise) its being pushed hard.
Why would you buy something then ask about it?
Wanted to see how you guys thought about my purchase. If i didnt buy it beforehand i would just keep shopping in circles.
So far, even in a smaller box, this 3xl turns lots of heads and RIPS the lows. My backseat belts slam off the backseats and my entire interior roof moves. All this on a tiny audiopipe apsm-1500
I also would like to mention you can tell this isnt a little wally world or best buy sub, its legit.
Im going to get it termlab'd on the 15th at a local competition.
JoeK
JoeK
Ringtown, PA
JoeK
