Low Budget 8" ?
Milker
I have a BMW Z3 Roadster and am going to put a custom box between the seats :thumbsup
Unfortuneately the wife has pulled my check book after buying the car and I can't go over 100$ on a sub.
I was looking at the Rockford Fosgate P28S4.
What you think?
The only requirements are:
Has to be an 8"
The box is no more than 0.33 cubic feet. So not all Subs will work.
Thanks for advise in advance.
P.S. I want some good shakin base so if I have to sneak over 100$ then so be it. //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
9
137
what ^ said. amp gain setting info, test tones are at the very bottom...
435
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
614
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
Some manufactures actually cut out some of the low end to prevent speaker damage to the factory speakers. I would consider trying one of these for...
Milker
Milker
No Way!
saywhat?
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
