loudest trunk?
I haven't read many posts on this thread but my truck did a legal 142.2 @ 40 hz SEALED at a DB Drag event in Indy, IN. With that setup just a single red top battery from Autozone, stock alternator, one DB Drive PT2000.1D, one DB Drive PLT15WD, and box was 4 cu ft at 39.5 hz with a stupid ~25 cu in port area per cu ft. But with my current setup I hit 145.8 SEALED at an eCrack event in Mt Vernon, IL. With this setup I just had same single red top battery, stock alternator, one DB Drive PT2000.1D, but two DB Drive PLT15WD's and box was 11.37 cu ft tuned to 40.17 hz with a low ~14 cu in port area per cu ft. Both boxes were built rather quick with no 45s and just minimum bracing. 145.8 probably isn't close to being the loudest in that category but it is what it is. All giving decibels are from a Term Lab used at both competitions while being completely sealed.
Haha, sorry thought the thread said truck not trunk.
except for allan won at worlds by 4 db
---------- Post added at 09:14 PM ---------- Previous post was at 09:14 PM ----------
allan hall.. 158dbs /thread
too bad chriss ran 0-1000 and alan ran 1001+...............
would you like the usaci web page results....
0-1000
steven 156
chris 155
matt 153
1001+
alan and lacy 158
schaffer 157
02 Camry (I have yet to hear of anyone do well on the mic in this car, terrible for numbers)
This is Street B for DbDrag, 2 12 BTLs on a AQ 3500.1, one batt up front, thats it for Street B, car off, sealed.
I did a 142.5, I have my subs firing forward and sealed for the trunk, my box is tuned to 33 hz, but I burped at 38 hz.
Windows down, I'm guessing probably around a 144-145. Shame is does bad on the mic.. I heard a 143 certified eclipse hatch and my car was FAR louder to the ear for being .5db quieter on the mic.
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
777
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
SPLaudio
SPLaudio
upstate ny
9515ROB
    May 24, 2024
    May 23, 2024
