loudest setup
taintedplay
dallas
ok change of plans. the acura 3.2tl s i might be getting only has a 105amps. I want the loudest setup with not upgradeing the alt and only like one big battery(dont have one yet)
i currently have two type r (12inch) running 1ohm on a aq1200d, and was thinking of doubleing that exactly to have 4 r's off two aq1200d's
also i have a hifonics 6408
can two aq1200d's and a hifonics6408 run off a 105a and one big battery? if not whats the best setup to do so?
One battery could probably support that, probably one of the bigger batteries powermaster offers. You should def do the big 3 if you havent already.
Also, are you running those AQs at 1 ohm?
yes running 1 ohm, and i have roughly 9cu feet so i should be able to put in 4 type r's. i just have to see the size of the face to see if they can fit in that way. (the baffle)
when i get the car big three is my first task
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
688
I had some 9500 series 12s by MTX that were some slamming subs!! Should have kept those along with those torpedo RE XXX 12s
15
I am doing an all JL audio instal on my new F250 SD . I'm using a Audio Control LC 5i Pro with a JL Audio XDM 700/5 and C3-650's in all 4 doors...
980
Id sit down and figure out exactly what all you will be installing for amperage consumption and add another 10-15% amperage useage on top of that...
21
taintedplay
taintedplay
dallas
taintedplay
    May 31, 2024
    May 24, 2024
