Lots of amps for sale Clarion Marine Rockford Alpine Phoenix Gold
timhof13
Michigan
The following amps are for sale
Rockford Fosgate
$150 Punch power t400-4 7.5-8/10 cosmetic 10/10 functional
$125 Punch power t500-1 7/10 cosmetic 9/10 functional gain knob cracked so you have to remove the cover to adjust the gain. The pot is plastic and it split where you insert the screwdriver. Also has a burn mark near one of the speaker inputs. Works perfect
Alpine
$175 Alpine 4 channel MRV-F345 75x4 @ 4Ohms
$200 each 2 Alpine mono MRD-M1005 700x1 @ 4Ohms 1000x1@2Ohms
All alpine amps near mint like 9.5 /10 very small blemishes
Phoenix Gold / with bass remote
• $250 Phoenix Gold Sd1300.5
• 125 Watts x 4 Channel / 2 Ohm
• 80 Watts x 4 Channel / 4 Ohm
• 800 watts x 1 Channel / 2 Ohm
• 500 watts x 1 Channel / 4 Ohm
10/10 functional 8/10 cosmetic has a few small scratches on the plexi and has some Velcro on the back. Nice amp power a whole system easily. Comes with Bass remote
$125 Clarion apx480m Marine amp
10/10 mechanical 8.5/10 cosmetic
• 80W × 4 Into 4 Ohms, 20Hz-20kHz @ .05%THD
• 115W × 4 Into 2 Ohms, 20Hz-20kHz @ .2%THD
See Above
See Above
You Pay!!!!!!!!!!!
I'm in the same boat and have a few posts on several forums so this is NOT advice but just sharing what's going through my mind and we can help...
10
4K
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
448
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
572
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
timhof13
timhof13
Michigan
timhof13
