Lots For Sell or Trade!!!
Beerdrnkr
Looking for Ipods, Rockford Fosgate 3sixty.1 or 2, loud and clean small box 10's, clean sounding 12's, x-box 360, and so on. Let me know what you got.
I have the following for sell or trade, let me know what you have and let's work something out!
MTX Thunder 502 2ch. amp
Amplifier Type Dual Channel
Bridgable Bridgable
RMS Power at 4 Ohms 90 W x 2
RMS Power at 2 Ohms 180 W x 2
Performance
Frequency Response 20 Hz - 20000 Hz
Signal to Noise Ratio 110 dB
THD at Rated RMS Power 0.1 %
Crossover / Equalizer
Bass Boost With Bass Boost
Bass Boost Frequency 40 Hz
Low - Pass Frequency 40 Hz - 200 Hz
High - Pass Frequency 40 Hz - 200 Hz
Other Features
Input Voltage 12.5 volt
MOSFET Circuitry Yes
Dimensions
Width 12.6 in.
Depth 9.75 in.
Height 2.1 in.
Audio Control EQx
Dual-bandwidth Equalization with Crossover
6 Band, 1/2 Octave Bass EQ
7 Band, Octave Equalizer
Two-way 24dB/Octave Linkwitz-Riley Crossover
Programmable Frequency Match (PFM)
Subsonic Filter
Line and Speaker Level Inputs
Balanced Inputs
Input and Output Level Matching Controls
Boston Acoustic S60 Components (no grills)
Nominal Size
6-1/2" (165mm)
RMS Power Handling - 55w
Peak Power Handling - 150w
Frequency Response (±3dB)
58Hz-20kHz
Impedance - 4ohm
Sensitivity (1 watt (2.83v) at 1m) - 92dB
Mounting Depth - 2-1/2"
Prefab Dual 12" Sealed Enclosure (local pickup only)
Custom box for 3 12's common chambered and double baffled (local pickup only)
3 MB Quart RWE-304 12's
4ch. Power Acoustik amp A600-4HP (matches mono DB series amps)
RMS Power Output: 85 Watts x 4 @ 2 Ohms
Birdged Output: 600 Watts
Signal To Noise Ratio: 97 dB
Frequency Response: 10-30,000 Hz
Bass Boost: 0-18 dB
Built-In Crossovers: HP / LP
THD @ 4 Ohm RMS Power: 0.02 %
Low Level Input: No
Built in Cooling Fan: No
Bass Control Knob: No
Dimensions: 11.25 L x 11 W x 2.3 H
Phillips Harddrive DVD Recorder/Player BNIB only tooken out to test it.
Custom black felt pool table (obviously local pickup only) $700 if buying
Sony Wega 46" rear projection tv (local pickup only) Cash only $650
Like new LG 160W Compact DVD Shelf System with USB Port
Model: LFU850
Gamecube games: Geist, Sims Bustin' Out, NBA 2k2, Madden 2004
Computer games- Lands of Lore Guardian of Destiny, Battlefield 1942, Medieval Total War, Iwo Jima, Morrowind The Elder Scrolls III Game of The Year Edition
Nice Corona Neon Bar Sign (REAL bar neon sign)
Kenneth Cole watch
College Real Estate Books
price shipped for the hard drive dvd recorder/player?
$125 shipped. It's brand new. Here are the specs:
This ultra slim DVD player/recorder is loaded with features and input/output options.
The Dolby Digital audio HDMI connection carries HD video and digital multi-channel audio A/V with one connection making it a snap to add the DVDR3400 to any home theater system.
The DVDR3400 is also equipped with component, S-video and composite video for superior picture quality and versatility.
SmartAlgo features patented self-learning adaptive technology that chooses the optimal write strategy for the particular disc that is being used ensuring quality recordings, regardless of disc format or quality.
Progressive Scan doubles the vertical resolution of the image resulting in a noticeably sharper picture.
USB Direct plays or copies photos & music from flash drives and card readers.
Simply plug in your device to the USB port on your Philips DVD system and choose to either playback directly from USB or to select your digital music or photos and record these from the device onto DVD for later playback.
The 12-hour record mode lets you record up to 12 hours of video on DVD+R double layer disc.
With i.LINK Digital Video input you can copy your home videos directly from your camera in their original digital picture quality.
The DVDR3400 supports dual media recording enabling you to create recordings on DVD+R/RW, DVD-R/RW and DVD+R DL discs.
Now you can buy any disc and the Philips recorder will always create fully compatible recordings, which can be played by any DVD player.
The DVDR3400 plays CD, (S)VCD, DVD, DVD+R/RW, DVD-R/RW allowing maximum playback compatibility.
Multi-format playability allows you to play most file formats for maximum listening and viewing pleasure, including MP3, WMA, JPEG and the popular DivX digital media format.
DivX playback enables you to play and share compressed high quality DivX video content beyond your computer.
With the VCR Plus+ system, all you need to do to program your video recorder is to enter the Pluscode that is printed next to each TV program in most TV guides.
Features:
I have no money but throw out some of your gear, I'll take anything into consideration. Wiring, subs, boxes, amps, xbox 360, PS3, Wii, or cash. I can do pretty good prices on all the gear.
Beerdrnkr
Beerdrnkr
San Diego
jacwood5150
