looking to get a amp
tolow93
ga
i am looking to get a amp to power 1 ma audio 120Xe it's stats are:
350W RMS
700W Max
Dual 4-Ohm Voice Coils
150oz. Double Stacked Magnets
Mounting Depth: 6.2"
Mounting Diameter: 10.9"
Optimum Vented Box: 2 Cu/Ft
Round Port Diameter: (2) 4”
Square Port Area: 25 Sq/In
Port Length: 15.5”
Optimum Sealed Box: 0.75 – 1.25 Cu/Ft
I am looking at 2 amps but i dont know which one would be the best to power my sub so i was hopeing yall could help me narrow it down. the frist amp is a Profile Baja HA700M Mono amp it's spec are:
Peak Output Power (4 Ohms)400W x 1
RMS Output Power (4 Ohms)200W x 1
Peak Output Power (2 Ohms)700W x 1
RMS Output Power (2 Ohms)-350W x 1
Bridged RMS Output Power (4 Ohms)
MOSFET Power Supply
Total Harmonic Distortion-
Signal / Noise Ratio-100 dB
High Level Inputs
Pre-Amp (RCA) Outputs
Variable Bass Boost at 45Hz-0/6/12 dB (Switch)
12dB/Octave Crossover (High Pass/Full/Low Pass)-LP (Built-In)
Variable LP Crossover Frequency-50 - 250 Hz
Variable 12dB/Octave Subsonic Filter-20 - 50 Hz
Variable Phase Control-0 - 180 Degrees
Fuse (s)-40A
Dimensions (2 1/4" H x 9 11/16" D)-13" W
the 2 amp is a MA AUDIO HardKore HK297 it's spec are:
Thermal, short circuit, and overload protection circuit
Platinum coated RCA jacks
Double sided epoxy PCP board
Platinum plated terminal block for power and ground.
Fully regulated power supply
Stainless steel heatsink
Fully adjustable hi and lowpass crossovers
0 - 18 db variable variable bass boost
Quite fan cooling
Full mosfet circuitry
2 ohm stable
THD: .05%
Signal to noise > 90db
2 x 150 watts RMS @ 4 ohms
2 x 250 Watt @ 2 ohms
1 x 400 Watts @ 4 ohms mono
Dimentions (2.7"H x 12.4"W x 6.3"L)
please help!!!!
How much do you have to spend? Frankly, I wouldn't take either of those. But, of the two, the Profile would be a little better (easier to wire). The only way the MA would work is if you wired one coil to each channel.
that particular ma audio amp won't be best because you have a dual 4 ohm sub and can only get a 2 or 8 ohm independence and that amp is only stable bridged to 4 ohms and won't put out much power at 8 ohms. profiles are solid budget amps along with us acoustics. i'm assuming your on a budget since you listed a profile. another brand to consider is autotek. good amps at good prices.
I am not looking to spend much at all like $75-80 I am 16 with out a job and i don't have much money I found these on ebay and they have the right amount of power to push my sub with the ma i was going to do like squeak said and wire one coil to each channel.but if you can find anything better than these for around the same price please show me. thanks
for that price level probably not going to find much better
i guess it would be better to wait and get little better stuff and I've all ready went thru the couch I've got $17 in change. but if yall see any more good deals on amps or cd players please tell me. thanks
why dont you get something used from someone on the site? Sorry, I didnt check out the model of the MA amp, I figured you have the right one picked out for the sub already...my bad.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7930857938&category=38638&sspagename=WDVW-Notice it's rated @ 12.9V
And I would take this Profile over the one you listed: http://www.thezeb.com/p-Profile-CL600M-Mono-Subwoofer-Amplifier-103514.htm - only $15 over your price range. You should be able to find that much change in your couch cushions //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
thezeb will price match millionbuy.com which is almost always much cheaper
Profile amps are great for the money I have one in my wife's car.
tolow93
tolow93
ga
Apoc
