Looking to buy quite a few things.
MutantDreams
1. 2 matching two channel amps that put out 30-50 rms per channel.
2. A cheap cheap voltage meter
3. A bypass module that will work for my cobalt (dball flcan etc)
4. 14+ ft of 9wire/speed wire
5. A cheap remote start+keyless entry. I'd prefer all in one, but i might be interested in one if i can add the other.
6. Blue led strips
7. Double din kit for a 08 cobalt
8. 8" subs 250-400rms
9. 800-1000w mono amp.
I have a memphis 4 ch in beautiful condition for trade
I have JL 9 conductor speed wire for $40, 20' and bnib power acoustik RZ1-2300D
  • Monoblock RAZOR Series Full Range Class D Car Amplifier
  • RMS Power Rating:
    4 ohms: 900 watts x 1 chan.
  • 2 ohms: 1400 watts x 1 chan.
[*]Max power output: 2300 watts x 1 chan.
[*]Pulse Width Modulated MOSFET power supply
[*]Wired remote bass level control included
[*]LED power (green) and protect (red) indicators
[*]Variable Bass Boost (0 to +12 dB bass boost at 50 Hz)
[*]Soft start turn-on
[*]Mono channel operation
[*]Speaker-level (high-level) inputs
[*]3-way protection circuitry (thermal, overload, and speaker short protection)
[*]Heavy duty aluminum alloy heat-sink for extreme heat dissipation
[*]Nickel-plated RCA level inputs
[*]Nickel-plated screw terminals
[*]Variable subsonic filter (10-50 Hz, 24 dB/octave)
[*]Variable low-pass filter (50-250 Hz, 24 dB/octave)
[*]Dimensions: 4-3/4"W x 11"L x 1-1/3"H
Do both for $180
MutantDreams
MutantDreams
Columbus, Georgia
nismos14
