darksparkz
I'm looking to add a Kenwood DNX8120 to a '07 Toyota Camry, I'm looking to have it be able to run with the car off occasionally to watch a movie or video or just simply listen to music. The car currently has the stock JBL system with a JBL amp and speakers.
I'm thinking of just getting an Optima YellowTop to hook up with a battery isolator. I'm just wondering how a setup like this would work, and would it eventually be expandable to be able to hook up an aftermarket amp later in the future.
(Positive)
Main Battery->fuse->isolator->second battery
(Negative)
Main Battery->Ground to Chasis
Second Battery-> Ground to Chasis
Does that sound right? I'm thinking the isolator would be able to allow the second battery to charge when the car is running too, would I need a switch or voltage meter or anything to help monitor the voltages or turn on/off the isolator?
Do I wire my Kenwood unit any differently to have it run power off the second battery? Or do I wire the stock JBL amp differently also to run to the second battery instead.
(Positive)
(Negative)
