Looking for suggestions on a 12" sub
Deamonicus
Johhny Bravo
I've got a 2 channel amp that will put out 200 wrms x2 @4ohms, 300 wrms x2 @ 2ohms, and 600 wrms x1 @4ohms. I would like to drive one 12" sub with that. It will be going in a 1 ft^3 sealed box. I am interested in SQ mostly. I would like to stay around $100 but if I can get better quality for a little more I may up my budget. //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
RE SE 12"... If you got 600 rms itll work, the SE and SX series are both dual 4 ohm. You wont get it for 100 bucks though, but the higher price will be well worth it. Around $250 shipped i would say.
RE Audio Retailer:http://www.mdaudio.net/cgi/RE/resubs.cgi
Would the dual 4ohm configuration of that speaker not eliminate this speaker? His amp does 600 RMS at 4ohms and I do not think you can wire a dual 4ohm speaker to achieve a final 4ohm load... Dual 2 yes, dual 4 no???? Please correct me if I am wrong.
Not trying to act like an expert, but i amp looking to order the same thing. If im not mistaken two dvc 4 ohm subs = 1 or 4 ohm load, so this would not work if he was only getting one 12?
//content.invisioncic.com/y282845/emoticons/search.gif.e79a63b2b580b39b282dff402646b704.gif
THAT DOESN'T WORK DICK HOLE!!!!! //content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif//content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif
Deamonicus
Johhny Bravo
Deamonicus
Under a rock
Deamonicus
