looking for box designer
Rogee
looking for box design for 2 AB XFL1544's going into a 2000 ford exedition. My demensions are 42w x 38d x 32h. Looking for 4 cubes 35hz. I've tried to do it myself with no luck so thanks in advance to anyone that could help me out. If you need anymore info please let me know. Thanks again.
Most people charge for this type of help. Time is money I guess. Sad but true
well ok i didnt know i was looking threw trying to find if its already been asked before i adk again i didnt see anyone saying anything about money. Thanks for your reply ill keep playing around with torres just thought some vets out there might been bored and could offer some help. Thanks again.
I was/am planning a build with 2 xfl 15's and i was told they prefer around 4cu ft per sub. So an 8cu ft (after displacement) would suit them perfectly. And the xfl series like to play the lows hard but you can tune them a little bit higher than 35 without losing any low end, i was told that 37-38 would help get the most out of them. So to sum up - 8cu ft, ported at 37/38 hz
I did some quick math for you: if you make the box 42w x 38d x 11.5h it will be 8.61 cu ft (assuming 3/4 mdf or ply is used), then add 2 ports - 5" diameter/6 inch long each (tuned at 37hz) - this will account for .15 cubic feet, making the box 8.46 cu ft before sub displacement, each sub displaces .22 cubic feet, 8.46- 0.44= 8.02cu ft. So 42w x 38d x 11.5h outside diameters should work perfectly.
Rogee
Rogee
cape coral, fl
BSchrowang
