Looking for an amp to power my sub
That amp has plenty of balls if you have it installed correctly. I installed one for the first time recently to power two Pioneer shallow 12s. Maybe you're expecting more out of the sub than it can give you. What enclosure is it in? NoLoud4U is on to something.
I probly do have it wired incorrectly. I don't know much about wiring amps and subs and the box is a ****** one but I'm getting a custom enclosure done by highoutput. I just wanted to see if anyone would have any other input.
All the lines are speaker wires.
So I don't need a wire connecting the other + and -? Also is there a specific way to connect it to my amp since my amp has inputs for 2 subs? I really appreciate everyone's help. Thank you.
No you are just using one pair of + and - dont even touch the other two + and - There is no bridging or anything like that, its a monoblock. Those are for if you using two subwoofers, it just makes wiring easier, you do not get more power if you use all of them. You get power if you wire it parallel properly according to the diagram
I have a pioneer ts-w3001d4 being powered by a pioneer gm-d9601. I just feel like the amp is really pushing the sub like it should. Any suggestions on anything else that would push it close to its limit?
i dont think that a 199.99 amp would even come close to pushing your subwoofer.any brands that you prefer or like?you can find the ARC KS 1000.1 every once and a while on ebay for 375.00 to 400.00.and now that you can buy extended warranty on used items on ebay i have been buying alot from there.JL also makes a very nice HD 1200 true watt amp.and it makes that power from 11-14 volts and 2-8 ohms.not positive about ohm range but something similar to that.i might be getting my hands on the ARC in the next few weeks if you like that one.google them and see what you think.
I tried wiring my woofer this way and it was non responsive. I'd didn't do anything at all?
Make sure you wire it properly man, you wired it wrong in the beginning, not sure if you made a mistake along the lines. Watch the video and get a digital multi-meter
If its completely 100% wired exactly right with a speaker jumper wire from positive to positive and negative to negative then connect a negative and a positive from the sub and connected straight to a positive and a negative on the amp. At 4:15 in the youtube vid.
If you still have no sound then you've blown a pair of voice coils from your improper wiring before. Watch the video, it'll show you how to check the voice coils with a digital multi-meter if you have a wierd reading then its blown.
escoriasza@yaha
escoriasza@yaha
tampa florida
CSCStang
