Looking for an amp for 2 12w7
used orion 2500d = $400 and 2500watts, dependng on final load. best amp for the money available anyehere in the world.
i dont need that much i only want about 1000 watts per w7..plus i have the stock electrical so i dont want to get something that will draw lots of power...so anyother suggestions
i have a yellowtop, 5 farad cap and a 140 amp alt but thats my stock alt...i will upgrade later right now im just looking for a good amp,
are planet audio 2250 any good?
or soundstream picasso 2000d
or or 2 jl 500/1
The point is that you have 2 SVC 3 ohm woofers, meaning that you'll need an amp that puts out 2000w at 1.5 ohms. So an amp that puts out 2500 at 1 ohm will be your best bet. And if you want to run 2 kW daily, electrical upgrades are a MUST. There is no getting around it. If you don't want to spend the money on electrical upgrades, I suggest you look into a smaller substage.
i ran my orion 2500d for a year on a stock toyota previa (80 amp altie)
zero problems,
and not even much dimming unless i was really trying.
or or 2 jl 500/1
The 5 farad cap is basically useless. 140 amp alty is fairly decent, especially for stock. And the 2 JL 500/1s won't give each sub 1000w. Besides, the 2 500/1s would cost around the same amount as the aforementioned Orion and a new HO alt.
i had an orion 2500d before and it ran fine with my stock electrical for almost a year but i got rid of it so now im looking for something else...i just need help with an amp thats all electrical system is going to be done same time amp is installed
I would go with a PG tantrum 1200.1
with good electrical u should see 1300-1400 from this amp which is plenty for 2 12w7's..
I'm running 1 12w7 off a 500/1 just fine
what type of enclosure
if sealed, you may only need 500 or 600 watts per sub
Um... sealed enclosures increase the amount of power you need to reach the same output. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
mysticillusion
mysticillusion
irvine,ca
nauc
NorthFramingham
    Jun 30, 2026
