Looking for amp under $100 for RE SE 12
abcheng
I'm installing a RE SE 12 in my friend's car soon, and trying to keep it under his budget of $300, $250 preferably. The sub costed me about $160 which leaves me with ~$90-100 left over for the amp. Can anyone recommend any amps around that price that pushes ~400- 600W RMS @ 2 ohms? The only amps I have found so far that fit my criteria are: the Ma Audio M683I and the Visonik V217SX. It's hard to find amps that push 600W @ 2 ohms without spending $200 or more.
i have a used phoenix gold xenon 400.1 i'd let go for $100 shipped. missing the bottom two rubber covers where the wires go (cosmetic only). they typically go for ~$140 shipped new on ebay. the 400.1 is rated for 400wrms x 1 @ 1-4ohm but typically benches in excess of 500wrms.
Profile AP1000M
Peak Output Power(4 Ohms): 650W x 1
RMS Output Power(4 Ohms): 310W x 1
Peak Output Power(2 Ohms): 1000W x 1
RMS Output Power(2 Ohms): 500W x 1
Bridged RMS Output Power(4 Ohms): N/A
MOSFET Power Supply
Total Harmonic Distortion:
Signal/Noise Ratio: 103 dB
High/Low Level Converter(Male RCA)
Pre-Amp(RCA) Outputs
Variable Bass Boost@45Hz: 0 - 12 dB
12dB/Octave Crossover: LP (Built-In)
Variable LP Crossover Frequemcy: 50 - 250 Hz
Variable HP Crossover Frequency: N/A
Bass Level Remote Control (16.4 ft)
Variable 12dB/Octave Subsonic Filter: 20 - 50 Hz
Variable Phase Control: 0 - 180¡Æ
Fuse(s): 2 X 30A
Dimensions (WxHxD): 13 5/8" X 2" x 10 1/4"
Power/Speaker Terminal Size(Gauge): 4/6
i got my profile for about 116 shipped. u should be able to get it cheaper on ebay.
i have a mtx 250d if u want. does 350 @ 2ohm underrated. really does about 400+ at 2. pm me if interested.
abcheng
abcheng
Atlanta, GA
soul05
