Looking at the JL AUDIO XR570-CSi
AllStar1500bd
Times have changed
I am looking into buying the 2004 JL AUDIO XR570-CSi 5x7 comps.
In comparison to the MB Quart Reference RCE268 comps, which would be more clear as they get into higher volume? I will be pushing my new comps with a RF 851x, so the louder I can get them, the better....
Here are the specs on each...
MB Quartz
» 6"x8" polypropylene woofer with rubber surround
» 3/4" titanium dome tweeter with composite surround
» composite ABS/fiberglass basket
» outboard 2-way crossover (4,200 Hz at 12 dB per octave) with 4-level tweeter output adjustment
» tweeter grilles included (no woofer grilles)
» frequency response 38-32,000 Hz
» power range 60-130 watts RMS
» sensitivity 86 dB
JL Audio
Nominal Woofer Size: 5" x 7" (125 x 180 mm) oval
Tweeter Size and Type: 1.0" (25 mm) Aluminum Dome
Continuous Power Handling: 85 W per channel
Recommended Amplifier Power: 40 W - 175 W RMS / ch.
Nominal System Impedance: 4 ohms
System Efficiency: 90.5 dB @ 1W / 1m
System Frequency Response: 48 Hz - 25 kHz ± 3 dB
Will the JL's get a hell of a lot louder just looking at the specs?
I can get them both for the same price..... which should I go for?
AllStar1500bd
Times have changed
AllStar1500bd
Oregon
AllStar1500bd
